Will Foxfi ever work again post JB upgrade?
Supposedly it does on Verizon, and for the S3, they found a hack to get it to work, so there's hope. Looks like it's something baked into JB that's causing the problem though.
bionic did OTA to jb and foxfi no longer worked. downloaded foxfi ver 1.9 to pc and transferred to phone and installed apk file. changed name from foxfi00 to foxfi02 and new password,
reboot and it worked. don't upgrade foxfi either, keep the 1.9ver no limitations on that one. the later foxfi vers have the limitations.
I installed the APK for PDANet and i can tether my Galaxy Nexus with no limitations. Foxfi nor PDANet are available on the Play store.
Foxfi you can get from their site, though they now throttle you if you don't pay. Can you for PDANet? Are you using OTA? is PDANet free?
Just use wifi tether if u are rooted
Sent from my Sprint Galaxy Nexus Rockin 4.2.1 using Tapatalk 2
PDAnet is free you can also get it from their website. Install it on you laptop and you are done.
It works on my gnex it all depends on what version app u have also easythether works on 4g only it has to be USB tethering
Sent from my Sprint Galaxy Nexus Rockin 4.1.2 using Tapatalk 2
kimlien
