Will Google Calendar and Keep Work On a Huawei P30 Pro the same as on a Nokia 8?
  • Start date Start date
A
Android Central Question
I currently use a Nokia 8 running Android 9, and synch Google Calendar and Google Keep with my MacBook Pro - using tabs in my Chrome browser.
Google Calendar has become an essential part of my online life - especially the ability to colour code events and organise things so seamlessly. It's an improvement on Apple Calendar that I used before.
This setup has worked faultlessly for the past two and half years, but I'm about to upgrade my phone - I'm considering a Huawei or a OnePlus, with the P30 Pro leading the field at the moment.
My question stems form seeing Google Calendar running on a relative's brand new Realme phone this week. The Google Calendar App was present, but was trimmed down far more that the version I use on my Nokia - lacking the ability to colour code events in the usual way.
Put simply - if I buy a new P30 Pro or OnePus 7t, will Google Calendar and Keep run in the same way as I'm seeing an using them on my Nokia 8?
This is a potential dealbreaker that could send me back to an iPhone. Thanks for your help!
You would have to find someone on here with both devices which is unlikely. I would suggest going to a store to compare the devices to make sure the layout is as you wish.
Welcome to Android Central! First, are you certain the calendar app on your friend's Realme phone was actually the Google Calendar app? Or could it have been the stock Calendar app?
Second, remember that newer Huawei phones still aren't certified for Google Play, so you'd probably have to sideload Google Play Services and other Google apps (which can be done, but it's not necessarily a straightforward process).
Please register on this forum, which will allow you to engage in discussion more easily, as well as post images. https://forums.androidcentral.com/ask-question/409154-join-android-central-community.html
vonsworld2000
