Will my S3 case fit S4, too?!
bigstomachking
Active member
Sep 25, 2012
29
Well. From those leaked picture, I didn't see much difference in appearance between s3 and s4. And I just browsed several phone case sellers' website, found nothing about S4 pre-order. So I wonder is it possible that the S3 case will fit S4, too?
Most likely no, from the leaks it's taller and thinner so any snap or tight fitting cases probably won't work... There will be plenty of cases announced following launch
Sent from my SCH-I605 using Tapatalk 2
You will need a bigger case as the GS4 has a 5" screen, a special that should be confirmed later today.
Sent From My Samsung Galaxy Note 10.1 Tablet
The flash looks to be under the camera lens on the S4, while the flash is next to the lens on the S3. I guess we'll find out the final design tonight.
It won't fit.
I was told from a good source that dimension-wise, the edges and corners are shaped bit differently and that the phone's super thin. Thinner than the iPhone 5
Yes. The truth is it won't fit..
But I really like some features of GS4! I am 99% sure I'll get one.
So come one guys~ Let's share photos of S4 case!
Otterbox already announced their cases for the gs4 will be Available
The S4 has a pentile display. Grainy, White's and grays look the worst. But overall it's grainy... You're better off getting the Note 2. I can't believe Samsung did this again. I thought they would have learned. They put a awesome screen on the Note 2 then use pentile on there new flagship device? Yeah it's 1080p but it's pentile. Such a sad day. I guess that's why they are talking about the software so much. Even though it's just 4.2.2 and they changed some of the new features to S-drive, ect.
Sent from my SGH-T889 using Tapatalk 2
everyone is talking about the pentile display ... well. I think my eye will be used to it... i dont use iphone to compare anyway
Display aside as the OP asked about the case, the camera, flash and speaker grill are in the wrong place. As soon as I get both the phone and the case, I will try and post a review of the OB Defender case on my YouTube channel, TheJCP006.
cstraveloka
