Will Samsung bring back the classic S Note?
Coming from the Note 5, I didn't even know they did away with S Note. What I'm more concerned about is if my old Note 5 S Notes will automatically transfer into Samsung Notes on my Note 9 when I log into my Samsung account. I killed the screen on my Note 5 but had some pretty sentimental and important stuff in S Note. Anybody know?
If you had them backed up to your Samsung acct I think there's was a way to get them back, but I'm not sure. If you import them into Samsung Notes tho, they won't be in their original format. I believe there are topics about this on the N7 & N8 forums. (If I can find them, I'll link them here.)
Can you still access your N5 from a computer? I always move mine to new devices via my laptop. All S Note files, including Action Memos are in the folder named SnoteData. If you sideload S Note as explained, you won't lose formatting, and can continue to access/edit/create.
Thanks for the response. Yeah, they're backed up with my Samsung account, so hopefully that will work. And sideloading is a good idea, I'll give that a shot.
Just like @sandra_17 said, the format will be different, S Note reads like a book while Samsung Notes scrolls up and down.
(Side note, the blue looks like the blue of my N5 to me. The lavender actually doesn't look as pink as photos make it look, maybe because it's more metallic/chrome looking?, but still too girly for me. Tho I would have loved dark purple.)
I thought that too. I believe it was called Sapphire Black on the N5. If only the N9's pen matched.
It's driving me CRAZY! And none of the other colors go with that blue any better :/
Why???? Just WHY???? I cannot believe someone thought that color combo was a good idea. If I wanted a color combo I'd buy the Spen of my choice.
2 options I am really considering:
- Buy black S pen replacemnet
- Pull out the blue spray paint
btw jk :)
I hope someone from Samsung reads this.
Dear Samsung,
You've listened to your customers regarding things such as bringing back the SD card, fingerprint reader placement and increased battery size. PLEASE bring bring back S-Note or at the very least, bring S-Note features to Samsung Notes.
Sincerely,
A Galaxy Note Fan
Yeah, it makes it more annoying when you have just one other colour choice, but me, I do like the combination.
Made it into BestBuy today, but the two Note 9's they had to look at were both in "Retail Mode", so if wouldn't let me install anything. Didn't have enough time to stop in VZW - last year their N8's were not in retail mode, so I got to try to install, which didn't work. But I think that I screwed something up that day trying tho.
I installed several launchers and apps on the retail model at my BB... wanted to see if Action Launcher worked for Pixel-like -- it does. I wouldn't let me sideload the apk for Action memo.
Well it didn't long last year for someone to get s-note/ action memo working for the note 8. Hopefully the same for this year. Keep our fingers crossed.
I'm going to keep using it until it's not supported. Hope that doesn't happen.
I just downloaded an older version of S-Note and the Action Memo shortcut and it works -- UNLESS you disable the notification that "S Memo is running"... then you have to reboot and it will work again from the pen menu (shortcut for Action Memo) -- I don't remember what the "picture note" is, but the features I remember from Note 2-3-4-5 are working...
I just downloaded an older version of S-Note and the Action Memo shortcut and it works -- UNLESS you disable the notification that "S Memo is running"... then you have to reboot and it will work again from the pen menu (shortcut for Action Memo)...
I just finished installing. Used the same version as with the Notes 7 & 8 - 5.2.04.25. Seems to be working as it should (still no PhotoNote or EasyChart).
I don't see the error you're getting. Maybe try this version when you can.
Thanks for this handy reference. I just downloaded the S-Note compilation on both my Notes 8 and 9. Works like a charm!
Sonfollower28
