Will the Otterbox for the Note 3 fit my charging cable?
maxc50167
7
Does anyone have the measurements of the Micro USB 3.0 opening for a Note 3 otterbox? I want to make sure that my charging cable will fit through the opening on the otterbox.
All I need is the length and width of the opening for the otterbox. If the size is bigger than my cable connector, i will most likely buy one.
Thanks!
I have the Commuter case. The OEM issue cable works just fine, as does one from my old Note 2, and several other older Blackberry issued cables. No problems for me with any of those.
