Will you use wireless charging with the note 4?
thegame161
1,298
I've personally got the Samsung pad from the note 3 and thinking about buying the wireless s view Cover
Yuppers! I'm using a choetech coil and one of those USB receivers. I use a case so i tuck it under so it can't be seen. Works like a charm.
I ordered the very cheap chinese made qi pad and charger off fleabay. Ill let you guys know if it blows up or works.
As soon as the Samsung wireless charging back is available I will go to wireless charging. This will also provide a better back cover surface that the Verizon version of the OEM back cover which is harder and slipperier than anyone else's OEM back cover.
Just ordered Wireless Charging Flip Case from Verizon. Pricy, but, it worked great on my note 3
