Wiped System, OS Gone.
StormyJet1
Hello.
As you can see by the title, I (accidentally-ish) wiped my entire SDCard and Internal Storage. No OS, and no backup roms or backups. I can boot into both Recovery and Download Modes, (if it helps, I have TWRP recovery)
There is NOTHING on any of the storage places. No superSu, nothing. :/
This is the T-Mobile Galaxy S3, sgh-t999/d2tmo
plsrespond
Thanks a bunch in advance.
Have you tried downloading the originalbstock odin file and flashing it via odin? That should get ypu back to square one and allow you to reroot and reflash your rom
Sent from my SCH-I605 using Tapatalk 2
I would, but I cannot find the stock rom for my GS3.
(USA, T-Mobile, can get 4g)
There's always Kies - here's an overview of what to do:
- if you don't already have the Kies software installed on your PC, download it (just search Google) and install it. The first time it runs it'll update itself to the latest version so make sure you run it once before proceeding.
- put your phone in Download mode: with the phone completely off, press and hold the Volume Down and Home and Power buttons simultaneously, and release them all when you see the Samsung splash screen
- connect the phone to your PC with the USB cable that came with the phone
-- if you've never had the phone connected to your Windows-based computer before, you'll see messages about installing drivers, etc - just wait until this is done (may take 5 or 10 minutes) [I don't know what happens if you have a Mac - it probably just works]
- in the Kies software, select the second item in the Tools menu and just follow the prompts to enter the model number (in CAPS) and IMEI/Serial Number (both found under the battery - it's ok to remove the battery at this point)
- the Kies software should start downloading the correct firmware for your phone from the Internet; once that's done (depending on your Internet connection speed) it'll begin downloading that to the phone (this probably takes 10 minutes or so)
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
ZackS
