Wireless car mount
Hairy Brain
Active member
Apr 8, 2017
43
With my S10 plus pre ordered I'm getting ready to embrace the wireless charging life.
Anyone recommend a decent car mount?
No specific recommendation, but I would say you should avoid magnetic car mounts. If you have to insert a metal plate into your case, it'll interfere with wireless charging (and PowerShare too) and you'll need to take off the case every time you charge.
iOttie makes a decent one. I picked mine up at best buy for around $50. My only issue with it is it won't stick to the little disc it comes with for sticking on your dash. It sticks really well on the windshield though and it's fast charging. So you can use navigation and Bluetooth music and it will still charge.
iOttie Easy One Touch Qi Wireless Fast Charge Car Mount Kit for Samsung Galaxy S10 S9 Plus S8 S7 Edge Note 8 5 & Standard Charge for iPhone X 8 Plus & Qi Enabled Devices + Dual Car Charger https://www.amazon.com/dp/B0754NDNT...ag=hawk-future-20&ascsubtag=UUacUvbUpU6477696
I had an iottie before I like it but a piece broke off and they sent me another and the same piece broke off. I'd like to have a wireless car mount that one seems nice. Wonder if newer 2.0 ones will come out specifically for the 10.
iOttie Easy One Touch Qi Wireless Fast Charge Car Mount Kit for Samsung Galaxy S10 S9 Plus S8 S7 Edge Note 8 5 & Standard Charge for iPhone X 8 Plus & Qi Enabled Devices + Dual Car Charger https://www.amazon.com/dp/B0754NDNT8...cUvbUpU6477696
This what I have and it was just perfect for me. Been using it for about a year.
Thanks for the suggestions, I'll have a wee look. I should have added that I'm in the UK so sometimes Amazon is lacking certain things.
I thought about a wireless one but then I use android auto so that keeps charged anyway and I can't use AA wireless.
I own this one and it works great with my s9 plus and iPhone XS max. I use a pro clip to mount it on my dash.
iOttie Easy One Touch Qi Wireless Fast Charge Car Mount Kit for Samsung Galaxy S10 S9 Plus S8 S7 Edge Note 8 5 & Standard Charge for iPhone X 8 Plus & Qi Enabled Devices + Dual Car Charger https://www.amazon.com/dp/B0754NDNT...ag=hawk-future-20&ascsubtag=UUacUvbUpU6482565
Strange... I have had iOttie for years never had an issue.
Bry
