Wireless Chargers for Note 9
xrandolph1017
I'm switching from Apple to Samsung after the S10 comes out so I can hopefully get a lower price on the Note 9 (Fingers crossed). I'm looking to get a wireless charger but I'm wondering are they worth the money? If so what brand do you recommend and how fast does it normally charge your Note 9? Thanks
I like the Samsung fast charger with built in fan, haven't had issues .
I have one of the older Samsung fast charge stands. Its on my nightstand for when I go to bed.
I also have one next to my desk, but it's a choetech usbc unit. Anker and Aukey are also top brands from my experience
Those brands definitely hear good things ..
Yes Samsung wireless charger w/fan works best for me.
In the car. I use a
Crave car hub 19.99 Amazon. I use it simply because of the extra ports for dash mini camera as well.
Never had any issues even while phones are in use, charger still is able to fill batteries before being depleted.
There's always plenty of cheaper chargers out there. Just remember the Type C cord that comes with Samsung really should be the cord you use.
3rd party cords just don't hold up and I wouldn't put them in my phone anyway.
But if you had to use a Type A to USB C then Belkin is s good source as well.
Just compared Belkin and Anker USB C cables. Sometimes you are paying for the name.
The cheapo brands at grocery stores and Walmart are definitely not worth it though. Same for the batteries
Ellesye 3 coil QI wireless charger works great! $19.99 on Amazon. Been using it for several years and never had a single issue.
My wife uses a CHOETECH Wireless Charger, Qi Certified Ultra-Slim Wireless Charging Pad. It fast charges, if you have a fast charging wall brick connected.
It works through the Samsung Rugged Protective Cover.
It's correctly priced $14 - $15, depending on color choice, on Amazon.
sa1234
