Wireless chargers for the Priv
Fyi, my charging continues to be flaky. I think I will see if today's upgrade helped, and if not, open a new support ticket.
@elcheapodeluxe the phone that you have is it the att variant? I'm wondering if the att version supports pma, this solution seems the cheapest and get and extra battery.
My phone is the non carrier branded version. I don't know the official specs on the AT&T version. The shopblackberry version supports Qi and PMA both.
It's what charger you have. Get 2amp charger.
Aukey
4.5 out of 5 stars**1,777Reviews
Aukey PA-U28 Qualcomm Certified 18W Single Port USB Turbo Wall Charger with 3.3ft Quick Charge USB Cable for Android Smartphones, Black
On Amazon.
I use a QI wireless charger1 (Insignia) that I picked up at Best Buy for about $30.
What's the most powerful wireless charging mat?? One that outputs the highest mAh.
Or is wireless charging mAh limited?
For those using a tylt vu... Is your Priv heating up beyond what is normal for qi charging? I remember my nexus 4 used to get warm on the tylt.
Are all of their darn models called Tylt Vu? I've got the easel one and it does not seem to heat up the times I've used it.
My phone developed other problems, and i did a factory reset. Both my wireless chargers work fine, now.
No, the phone doesn't get too hot on the tylt vu. It did before the factory reset, though. It got too hot sometimes when i was just using it, as well. I only wish I'd done the factory reset sooner.
jeffnachatilo
