Wireless Charging stand with a big shelf? I have a Pitaka case and a Phonefin my phone.
lonestar1135
48
Hello All
I have a Pitaka case with a PhoneFin on the back.
The Samsung wireless charging stand I have works, but I have to angle it a certain way so it doesn't fall off. I tried a flat wireless charger but it doesn't make contact.
Does anyone know of a wireless charging stand with a big shelf/lip at the bottom that could hold a phone with a little more depth?
Anker Powerwave stand also doesn't work.
Thanks!
hmm...That's tricky. It's difficult to use wireless charging when you have a phonefin on the back of your phone. Even though you can manage to make contact between your phone and the wireless charging stand or other wireless chargers, it may not work very well. As I understand, the receiver coils is located at the center of your phone, at least for most phones, so if the coils doesn't contact directly with the coils on the charger, there will be a problem.
r3dpuk3
