Wireless Charging
  • Start date Start date
A
Android Central Question
I just bought a LG V10 901 I would like to add wireless charging how do I go about buying the back door the phone and a comparable charging pad ???? Tia Ray
Try eBay. Look for lg v10 charging back. Any Qi charging pad will work.
I bought one on Amazon awhile back. I found that it made the phone extremely hot while charging so stopped using it.
That's one reason I stopped wireless charging too. the charging plate generates heat and if the phone sits on top of it, all that heat ends up heating the phone. And heat's bad for the battery, which is usually very close to the back of the phone.
But he asked.
I bought a Qi charge battery door a while ago on amazon. I also found it made the phone get warm so I stopped using it.
DonJrPlayz1234
