The other day I noticed I could never hear a sound from the speaker, no music, no phone, nothing. I plugged the headphones in and the phone works fine. I did manage to make the phone "boop" through the speakers when changing the volume, but still get nothing otherwise. My buddy said use compressed air in the hole, his iPhone has a similar issue, but no luck.
Has anyone ever heard of this issue? I don't think anything is broken, but I think the phone thinks that headphones are plugged in all the time.
I have an LG G2X on T-Mobile
SOLVED: So I tried all the hardware fixes above as I was pretty sure this was hardware related. It occurred after using it outdoors a lot on a particular humid day. I did the Q-Tip trick to no avail. I then blew into the hole like a nintendo cartridge with no results. I then sucked air out of the hole hard. This fixed the problem. I then put headphones in and out and the problem came back. I repeated sucking air out of the hole hard several times and tested again. The problem remains fixed now. I can only assume it was either moisture, a particle, or some combination of the two.
Just did a factory reset, no go, same issue.
F#$%
