Xoom Issues - HELP
barry.weston
5
I have xoom running the ICS update. Since the update the device will lock up and screen will go black. Only solution is a soft reset, the factory reset.
Even is there is no additional apps installed it does this. It will work for 3 hours, a day, then I need to do it again.
Any ideas will be of great help!
There is no official 4.1 for the xoom to my knowledge, or is there?
I would like to avoid having to root and install a custom rom.
Which Xoom do you have? Wifi only or 3g/4g? Where are you? The wifi only Xoom in the USA have the official Jelly Bean update. I cannot speak for the rest of the world but am sure someone else will chime in.
Sent from my Bolt
Xoom wifi USA has jellybean update, I updated weeks ago.
Sent from my SAMSUNG-SGH-I747 using Android Central Forums
Johan
