Xoom Portfolio Case Mod II: Charging Port
Ok I modified my case and here is a photo.
Used my dremel and xacto knife to cut the hole.
Not super pretty, but at least it's functional now.
I do plan on putting either some epoxy or other glue around the edge to keep it clean looking.
I used the end of an RCA Cable. I pulled out the pin, cut the end off, lined it up, held it in place with a pair of pliers and banged away with a hammer. It is EXACTLY the right size.
Reactions: skelzer
Took me a while to find a perfect fit with a pen.... wish I had thought of the RCA cable, they're everywhere. Good stuff!
Fantastic job. I have no problem doing little mods like this and end up having to do them a lot on my stuff. Definitely going to do this. Might use my dremel though. It generally just does everything I need it to do really well.
What material is the case made of? Appears to be almost a fabric? Its the case I plan on getting when I buy my Xoom with my tax refund
Suggest avoiding a dremel. Case has a fabric weave, could end up pretty messy....
I used a point tip grinder from my dremel and placed painters tape on outside to limit tear out. The outside is plastic so go slow so it don't melt. It worked fine, just wish my hands were more steady
I know right? I was finaly able to justify to my wife why I was saving all of those rca cables that came with all of our old vcr's and dvd players since everything we have is hdmi now.
Lol I get that man
Sent from my PC36100 using Tapatalk
Whoa I almost thought in picture 2 that you made a pen that can charge a Xoom. Good work though.
maryhurst515
