Xperia S: in serious need of help!!!!
Mar 9, 2014
8
Ok so I done such a dumb thing and deleted the stock download manager on my Sony Xperia s, my phone is rooted I have titanium backup and it shows up in there, I try to restore it but nothing, I cannot download anything at all or use Google play now, what can I do? Please help!!!
Re: in serious need of help!!!!
Hi! Replied to your other thread: http://forums.androidcentral.com/ge...d-stock-download-manager-rooted-xperia-s.html
Just to help other people I have fixd it my self with no hastle, I simple reinstall d the app from my titanium back up (app only) I then went into my settings , apps, went to all apps, found the download manager and uninstall d the updates and some how that has fixed my problem, I can now download stuff and use Google play again, it actually works better than it did befor, I hope this helps others :)
Thanks for posting the follow up. Glad it is working again. See you around the forums.
OptimalMaximus
