YCCTEAM Wireless Charger Review
Bruno Slivar
121
12
18
I received Wireless Charger Pad-YCCTEAM
Charger look so cool. Blue light. 3 coil for charging.
I try with case and phone was charging. With none problem.
The workmanship of the charger is good. The only minor problem is the speed of filling that noticeable after a long time used a quick charger.
https://www.amazon.com/dp/B01DTSTVGI?tag=hawk-future-20&ascsubtag=UUacUvbUpU5359296
Please provide more information with regards to reviewing the device. Such information that would be deemed useful for readers include:
Do you need to position the device in a certain part of the charger for it to work?
How long of a cable is provided?
Are the lights bright and are they a nuisance when you are trying to sleep at night? Some people are sensitive to light, so this would be important to include.
Additional specifications (e.g. size)?
Thank you.
Tnx.
No need position phone on some specific place.
Cable is 1m.
When phone is charging, i dont hear anything.
Blue light is not strong and in dark of the room i cant see on wall or any other place. Just the charger light.
Size is 10.8*62*122mm
There are non-slip pads on the top of the charger and on the bottom to keep the charger and your phone from easily sliding off.
