Bkdodger1
- Jun 27, 2019
- 6,044
- 6,906
- 113
That's probably lighting or magnetic attachments he used.There a defect in the weave? Looks like a crease around the bottom of the ring.
I've had a previous one and i it was a nice feeling case but did add a little bit of bulk.Anyone try the Dbrand Grip case? Wondering if its not to bulky
Did the Anker pack attach properly, or did it require manual adjustment like the Lisen? Which Anker pack are you using?With thinborne case mag safe works great. Use it with home, car, and battery banks. I have the Anker one and a cheap Lisen one from Amazon
The Lisen one was a little crocked, but you can straighten it by hand.
All my MagSafe batteries fit without any issues.Waiting on my Fold 7 so can't check myself but looking at this pic it looks like MagSafe battery packs will not fit due to the bottom camera sitting below the top of the ring. Is this true? Can I get some pics of battery packs fitting on the ring on your cases?
What good is the ring then if you can't attach packs, wallets, etc? Just to attach the round charging pucks??
Did you get your Pitaka yet? Any pics? Thoughts?I just pre-order the pitaka case. It's not military grade, but it feels like the phone has no case and gives it minimal drop protection,mostly for grip though.
How did you buy a front protector by itself?Still waiting on my thinbourne, but it may not be needed.
Raptic Aramid case mag safe with a tocol screen protector. Case doesn't come with front protector, so I bought a different Aramid front cover. Case and protector are a perfect fit. Highly recommend.![]()
I'll have to check, but I got it from Ali I believe. I use Temu, and DH gate too. I had to purchase the whole case, but it was about $15. I use all 3 at times. It actually arrived pretty quick too. The front cover and raptic case are a perfect match.How did you buy a front protector by itself?
I also got a cheap temporary one for $15, a Rucky. But I've been impressed by the quality, magnetic hinge protection, built like a tank. Absolutely seals out dust, because I've been hiking in hot dry dusty conditions and kayaking in the rain both with it.I have not found any that I really like. I did order a cheap, temporary one until I can find one.
Amazon.com: Osophter for Z-Fold 7 Case: Clear Transparent Protective Phone Cover[Anti-Yellowing][Anti-Scratch] for Samsung Galaxy Z Fold 7 Case-Black : Cell Phones & Accessories
Amazon.com: Osophter for Z-Fold 7 Case: Clear Transparent Protective Phone Cover[Anti-Yellowing][Anti-Scratch] for Samsung Galaxy Z Fold 7 Case-Black : Cell Phones & Accessorieswww.amazon.com
I ordered a cheap clear case on Amazon with a built in screen protector and it's horrible. Hard to hit the FP sensor because the front cover has no cut out, adds height to the camera and the case is a fingerprint magnet. I've had clear cases before and fingerprints were never this bad.I ordered the Samsung Clear case with magnet. After discounts and rewards points paid around $8 which is probably fine for this case.
Galaxy Z Fold7 Clear Magnet Case Transparent Mobile Accessories - GP-FFF966YCATU | Samsung US
Discover the latest features and innovations available in the Galaxy Z Fold7 Clear Magnet Case Transparent. Find the perfect Mobile Accessories for you!www.samsung.com
The Anker one attached perfectly it is the Anker 622Did the Anker pack attach properly, or did it require manual adjustment like the Lisen? Which Anker pack are you using?
None.... funny the way he says Harmless.... lolAnyone having issues with Harmless Karl at CaseBorne?
They must be out of stock and holding off on freebeesAnyone having issues with Harmless Karl at CaseBorne?
I might end up going this route and just add a screen protector. I have insurance on the phone so might as well go half naked.I just pre-order the pitaka case. It's not military grade, but it feels like the phone has no case and gives it minimal drop protection,mostly for grip though.
