Zenfone 2 Bricked need help.
paintedbrain
4
Hi My Zenfone 2 is bricked, I need some help if possible please.
When my phone got bricked I pulled out the sd memory card and this made no difference.
Here is what happens. If I power the phone on it loads the Asus logo and sits in a boot loop with the loading wheel spinning, nothing loads.
I can load the recovery window by holding volume up and power then releasing power to bring up the first menu.
I press volume down to select recovery then press power button to select it. An android error appears as a picture of android on its back with chest open.
Then pressing power and volume up should load a menu but this does not load. Some yellow text displays with an error message and then it goes back to displaying the android error.
Any help would be appreciated.
You should be able to boot into the bootloader, flash a custom recovery like TWRP, and then flash the zip image.
04ijordan
