ZeroLemon Case arrived
so I got my Zerolemon the other day, and i'm still in the progress of calibration... but I have to laugh because this thing has been at 1% for almost 10hrs now and still going .... :D
also getting used to the extra weight and it's actually not that bad. this thing is pretty awesome
**edit** my battery finally died. I think that the total time at 1% was between 10-11 hrs. that's just nuts. never had a battery like that before.
Do not let the battery die out to 0% . It decreases the overall life span of the battery.
I have a problem when the battery goes below 5%, the screen will start to dim, the brightness bar dissappear.
I have tried root dim, lux autobrightness but still doesn't work.
Even at 1% I can use it for another 12 hours, so I really need enough brightness to see it during afternoon, no problem at night.
Have to root to fix that. Then install Wanam or Xblast
I have had mine for about a week or longer now. And there are down falls. The holister is week phone falls out all the time and yes i make sure my 800 dollar phone is clip in properly. Battery seems good and case is pretty good. Battery blocks speaker a bit but i havent notived a differnce in sound.
The zerolemon tempered glass purchased 9.99. Is crap doesnt cover the whole actual screen still edges exposed lime it was cut incorrectly. Email waiting on response.
The tempered glass is meant to be cut short for the Note 4 because of the phone's curved edges. If the screen protector were to fit the whole screen then you would start to see a halo form on the edges of the screen protector
perusnehu
