Zerolemon extended battery for Note 4
Size wise this will be like taping THREE Note 4s on top of each other, more than 3/4" thick.
I hope the holder works well because I cant imagine this fitting in anyones pants pocket.
I just pre-ordered my new Zero Lemon monster battery. At 1mm smaller than the Note 3, it will fit in my pocket just fine. After all you need something to keep you grounded on a windy day!
So I am on day 2 at 70% battery with the ZeroLemon.
OK, this will work just fine, it is like having a brick in your hand though.
How's the case itself? I like that there are covers for every port, including the S-pen, but how are the actual covers? do they feel cheap? How's the sound, since the speaker is covered?
What about the battery itself? how much of the case does it take up? if it doesn't take up the whole case, what fills the extra 'empty' space? I'm thinking about it but I'm just not sure.
CASE:
1. The case is bulky like the Otterbox Defender. It's pretty sturdy.
2. The ports are somewhat flimsy and muffle the sound slightly. It's a little annoying but if you are particular about the sound quality, you can gently cut off the port covers and restore the sound quality.
3. The back is recessed so much that it is tricky to get S health to work properly.
BATTERY:
1. The battery life is amazing. I can get 17-19 hours of SOT with auto brightness, location services, Internet, some games. You just have to be patient with conditioning the battery and the first few charge-recharge cycles.
OTHER QUESTIONS:
1. The battery takes up about 3/4 of the case and the rest is a plastic frame to keep the battery in place.
CASE:
BATTERY:
OTHER QUESTIONS:
It's heading towards 20 hours of onscreen time and has been at 1% for over an hour.... and no power-saving mode is on. If you were a light user, it could easily last a week... it's completely ridiculous.
How heavy is that thing?
Can you use it with one hand (referring to both weight and reachability of the screen).
Am still struggling to understand why this is needed..
Sent from my SM-N910C using Tapatalk
it's a very bulky case but I use it with one hand. And I am, statistically speaking, one of the smallest adults here (under 4' 11).
I just like the fact that I don't have to charge it often or remove the back cover to swap batteries.
Some people have high-risk, time-sensitive jobs where they just don't have the time to fiddle with chargers and extra batteries... they just need the phone to last long hours.
rvrsco
