Ok so I've been playing with new boot and shut down animations, but I haven't been able to successfully change the downanimation.zip. I've been able to change the VZW_bootanimation.zip to 4 or 5 different animations, and even was able to successfully change the boot animation to an animation I was unsuccessful at using for my down animation. (All I did was change the folders name from downanimation.zip to VZW_bootanimation.zip.)
With that said I've spent countless hours over the last week searching the forums of many different sites, but I haven't found a method that worked. This link describes the exact situation I encounter, but the solution didn't work.[RES] SHUTDOWN ANIMATION (downanimation.zip) for SENSE based rom - xda-developers
I've even downloaded pre-zipped files and used adb to push them with no luck. Here is one of the adb sequences I've used ( I've tried a few different ways to push, copy or move the file):
adb shell
su
/system/bin/chmod 777 /sdcard/new.apps (new.apps is where I put the file on my sd card)
mount -o remount,rw -t ext3 /dev/block/mmcblk0p25 /system
/system/xbin/busybox mv /sdcard/new.apps/downanimation.zip /system/customize/resource/downanimation.zip
I know this shouldn't be that hard, but I must be missing a step. Has anyone successfully replaced the downanimation.zip file?
Additional details:
1. I'm rooted
2. I replaced the boot animation quite easily
3. I zipped the file using 7-Zip as store only
4. The adb command moves the file and I can see it when I do an ls search of the folder
adb shell
su
Additional details:
1. I'm rooted
