Are you on wi-fi most of the day? That makes a HUGE difference with the TB. Even with the extended battery and leaving the screen off all day, I'm pretty sure my TB would be dead just on idle after 8-10 hrs when on 3G/4G only.
Here's a question to ask yourself...
IF I have a tablet or Laptop... running on battery only, would it make it through the day using it as many have spoken about in this forum.
I feel like I'm reading Monty Python... search for the Holy Grail !
Some manufacturers do.
I've read every DNA review out there, and it seems like (for the most part) the DNA's battery life is on par with the SGS3.
I live in the land of Long Commutes where I've actually _had_ to fill up my tank every day. It was not the EndOfTheWorld
I have a TB and take it off the charger at 6:30am everyday. I go to work, use when needed, and put it back on the charger around 11pm when I go to bed. I checked email often, look up a handful or things on the Internet and stream music or videos for probably an hour or two total each day. I'm not sure if people don't have jobs and are able to spend literally all day on their phone so 40 hours of battery life (may be a bit of an exaggeration) is necessary, but doesn't anyone remember the old days before smartphones when you had a nokia or kyocera and it was awesome and you used it and plugged it in at night? A days charge is enough for me. I'm looking forward to this phone or maybe the next similar phone after.
I'm one of the seemingly few that had a good to decent experience with the thunderbolt, but I'm thinking of waiting to read some reviews and then deciding... My upgrade isn't until the first week of December anyway, so I have some time. And I know, if you keep waiting for the next best thing you'll never buy a phone, but that's not an issue with me, I'll buy what I think is best for me soon after my upgrade is available.
Same here. We are a rare breeed. LOL! I have been very happy with my TB and get 36-48 hours with what I would consider might to moderate use. If I happen to use it more during the day (if I don't feel like working too hard that day), I definitely notice more battery drain but it always makes it through the day with 15-30% left. I am fine charging it when I sleep so as long as the DNA can get through a typical day for me, I am almost positively getting it, although I will be looking forward to the personal reviews we should be seeing over the next coupdl days.
Coming apparently from an HTC employee. Lol.
Sent from my SGH-T989D using Android Central Forums
There are other phones available, they are there so if you need them you go get them. Stop crying and get what fits your need. Want 8 hours of screen on time. I had razr maxx and that didn't even do that.
What's available? The Maxx has a weak camera and screen. I would not sacrifice this for battery. No one is asking for 8 hours of screen time. 4-5 will do.
Just pulled the trigger and ordered the Razr MAXX HD this morning. Played with it for half an hour in a verizon store, the screen was sweet. As good as any other phone in the store. Supposedly the camera isn't so hot but I don't care, I never use it. Other than that, the phone has it all. Got tired of waiting for another HTC phone that could measure up with the big boys.
But of course then the size of your phone would be the size of your tablet, extrapolate the size of your tablet to your phone..I have used my tablet for 6 hours straight watching movies, playing games and anything else I wanted to do and still had juice to spare. I have had it last 2 days with regular use with out difficulty. If my phone did this I would be a happy camper.
That is the problem, there are no alternatives. The weak camera is one of the reasons I can't pull the trigger on the Maxx Hd. Also, it only has a dual core processor which is the ultimate deal breaker for me. If someone could shrink down the Note 2 to the DNA's size and put the same 1080p screen on it I would be 100% happy!What's available? The Maxx has a weak camera and screen. I would not sacrifice this for battery. No one is asking for 8 hours of screen time. 4-5 will do.
It seems as if right now there's no phone without significant compromises. I ended up choosing the Maxx HD for the battery life, storage space, and nice OS which is very close to stock with some good tweaks. On the other hand its build has too many flaws and the camera is just passable.
I will say though, that the screen is NOT weak. It's very sharp and bright. Text looks good on it. I guess if perfect color fidelity is important to you, then it's not the best, but most people, including me, aren't going to care about perfect color fidelity on a sub-5" screen.
By the way, you're not actually going to get "4-5 hours of screen time" on the DNA. You'd only get that if you're running the screen for 4 hours straight, which you'll never do. Your real usage of the screen is interspersed throughout the day with the phone doing its syncing and stuff while idling, which uses up some of the battery.
