Hi there,
I'm new to the forums, please help me.
My HTC DNA is running CM 11.0 with TWRP being my recovery mode.
Today, CM released an update for 11.0, and I installed it via the cmupdater, which is the feature they have built in.
Since then, it has been boot looping into TWRP. I'm not sure how to fix it. I have already flashed cache, dalvik cache, and data, yet I still have it.
My phone is not showing up when I plug it into my laptop, so I can't put anything on it either.
My phone does, however, have 2 backups, which I made a while ago by using TWRP.
They're called the following:
"cm10.1 full backup."
"cm10.1 no recovery and no cache."
However, the backups won't show up under the restore list in TWRP..
What should I do?
Thanks in advance.
What should I do?
Thanks in advance.
