Flash on Incredible?
coolkatz321
Active member
Jul 9, 2010
42
I just installed the Skyraider ROM and can't seem to find Flash anywhere on my phone. Is it possible it wasn't installed, or is it called something different on the Incredible?
Echoes
132
I couldn't find it either after flashing SkyRaider, so I just googled an apk file of flash 10.1 and installed it that way. Works pretty well, but Hulu is still pitching a fit about working on Androids.
Qazme
2,703
26
Sorry to make this short and sweet, or bittersweet. I can sum this into two things and a prediction.
#1. Read the directions. Don't just do things without reading the directions, they are there for a reason.
#2. When did gifs have anything to do with flash?
Prediction: I see wall building materials on the horizon.......
Upstreammiami
2,098
482
Yes you do all thanks to you
Qazme
2,703
26
Just a bit more information. If you installed Skyraider it creates a folder on your SD called "Skyraider". Inside of that you will find a flash.apk to install. Use astro file manager. If you didn't know this read the directions again....
