Does 2.2 update include an AAC audio codec fix?
MatthewG
Has anyone know if the update to 2.2 includes a fix for Stagefright audio, allowing streaming of AAC audio (Pandora, Rhapsody, MOG music services worthless in 2.2 until streaming AAC audio files fixed).
sting0387
Active member
Mar 22, 2010
28
Streaming pandora works fine for me except for 1 thing. I used to be able to use the nagivation system and listen to pandora at the same time. when the gps needed to speak, it would pause the music, say turn left, then resume the music. with 2.2 it no longer auto resumes the music. its a huge problem on 2.2 and no one has a fix for it
iamtone
150
on this note i wish 2.2 would allow you to play .aac music files on ur droid... i have somee flawless music files from my itunes i wanted to play on droid and it wont read it
bigk
343
12
Have you tried other music players available in the market place? They might be able to read them. I haven't used them but it's worth a shot on the free ones. I just the stock player for now.
iamtone
150
yea i tried mizzing and btunes and doubletwist its the android software that doesnt allow that format playback i believe
TBolt
1,854
62
I take it you're not using the OTA release of 2.2. If not, you still have hope that the official update will solve your problem.
fillossofer
313
16
If you're asking if the audio sounds good in Pandora, etc. on 3G, then I can confirm that, YES, it sounds good again. I know that in the 8/1 leak it sounded terrible and people were complaining. I can only assume it had to do with the type of audio file being used under 3G connections. I'm running the RUU and Pandora sounds great again. Also, there is an option for high quality or normal in the settings.
1kanaka27
52
I'm using Slacker and it pauses and resumes just as it did previously when I'm using navigation....
drkrleitch
