JaeKar99
I recently read and re-read your post on installing boot animations. I am VERY new to rooting and flashing, but catch on fairly quick. I have a fascinate thats rooted and flashed to 2.2 with kernel 2.6.32.9 and build EB01 and I used Odin3 to do the flash. I know...pretty basic. But I am wanting a particular boot animation. I downloaded the zip and renamed it. I went in and just deleted my original bootanimation.zip using Root Explorer. I then copied and pasted it but when selecting paste, it would never show up. So I assumed it had to be flashed. So, this is where I dont really know the lingo, so I will simplify it by just telling you what I did.
Took battery out and put back in, held vol up and down and power and it booted to recovery (blue letters). I selected apply sdcard:update.zip. It then went to the CWM Voodoo Lagfix Recovery (red letters). I selected install zip from sdcard, then choose zip, then I selected my zip, then yes to install, and it installed. Then I hit the menu which took me back to the CWM Recovery and I selected reboot now.
I have since rebooted 5 times and still no custom animation?!
WHAT AM I NOT DOING RIGHT!!??
Please advise!
