Well I hate to say it, but I've tried everything and looked everywhere (including searches) for an answer to my issue; but when I try 1 click root, I keep getting Error: Device Offline. I've reinstalled all my drivers for the phone, and rebooted it as well. any ideas on how to fix it?
yes, that is all I've tried so far, I've gotten everything to work up until it goes to actually root the phone. It looks like adb sees my device fine, but it appears offline, is there any way to fix that, or would trying a different method be simpler?
edit: wow you guys are fast responding, I really appreciate that.
here is a screenshot of what I see:
ok, unzip the Fascinate root Dir
Put it as C:\FascinateRoot_v02
Then follow the instructions here:
http://forum.androidcentral.com/verizon-fascinate-rooting-roms-hacks/66762-samsung-fascinate-rooting-eb01-return-stock-remove-system-apps-other-how.html#post699908
Post #4
tell me what you see after you adb devices
