zero neck
The Ever-Living
thank guys i try on my PC when i get home, i will give an update once i try
Yeah I meant rename the recovery file itself, not the backup file, on the CPU
The recovery file is what you're going to try to flash manually via adb.
If that doesn't work rerooting is the way to go, and might actually just be easier to do in the first place if you feel like it.
