[GUIDE][Ubuntu] Compiling Android from Source
I sync'd the 4.1.1_r1 branch, entered "full_toro-userdebug" at the lunch menu since it wasn't listed, ran make otapackage, and the result is named full_toro-ota-eng.lordbah.zip. I wasn't expecting to see "eng" there but "userdebug".
That's completely normal :).
I'm having the same issue. After the error message, it continues like it's building, but only runs for a couple minutes and doesn't seem to actually produce anything. (i.e. no .zip or .img files using variations of "make -j#" and "make -j# otapackage")
Everything else seems to have run smoothly, and I can't find any issues with anything I downloaded for the build environment. Anyone have any ideas?
PS: This guide is phenomenal, I don't post much on here but I've been around for a little while and this is by far the most comprehensive tutorial I've ever seen. Kudos, D!
The link posted earlier had the resolution; you need to edit the file guava/src/com/google/common/collect/Maps.java and replace lines 228/229 with what's shown in green. See below:
- public static <C, K extends C, V> TreeMap<K, V> newTreeMap(
- @Nullable Comparator<C> comparator) {
+ public static <K, V> TreeMap<K, V> newTreeMap(
+ @Nullable Comparator<? super K> comparator) {
Reactions: dmmarck
Thanks! OP's updated with updated fixes/tricks. Also added a neat CM compiler app, will be test driving it this week.
I can certainly help as well, although I'll be crunching some numbers so I may be distracted a bit.
I was able to complete my build, installed it, and at the same time installed a certain gapps and they appear to work. I am able to install market apps/use gmail. Not sure if it's OK to post which gapps I used though. Thank you, dmmarck!
Sure, which GAPPs did you use?
And congrats!
To make up for my useless rambling earlier, on my build using Ubuntu 10.04, the methods listed in the OP for Java didn't work. What worked for me was:
sudo add-apt-repository ppa:sun-java-community-team/sun-java6
sudo apt-get update
sudo apt-get install sun-java6-jdk
Also, this last line was unnecessary for me, but apparently you can also type this if need be:
sudo update-java-alternatives -s java-6-sun
Hopefully that helps the next person that has issues. I discovered that tip from here.
Reactions: dmmarck
Thank you! That should work with 12.04 as well. I'll put a link in the OP to this very post and that source.
Thanks again, I appreciate it!
Reactions: KWKSLVR
Give it some time; it may be hanging. If it sits there for an hour or so, then I would probably wipe out your WORKING_DIRECTORY and start anew. It's fairly difficult to get a good build out of a directory that hangs like that, for it could have bad stuff (it's just safer to start over really; yes, it can be done as is, but still).
Ok thanks
If the "$" shows up, then you can do "repo sync -f" to try and get around it.
What follows is a series of head scratching errors that all the Googling in the world hasn't helped me with:
find: `src': No such file or directory
PRODUCT_COPY_FILES device/generic/goldfish/data/etc/apns-conf.xml:system/etc/apns-conf.xml ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_MissedCall.ogg:system/media/audio/notifications/F1_MissedCall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_New_MMS.ogg:system/media/audio/notifications/F1_New_MMS.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/F1_New_SMS.ogg:system/media/audio/notifications/F1_New_SMS.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Buzzer.ogg:system/media/audio/alarms/Alarm_Buzzer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_01.ogg:system/media/audio/alarms/Alarm_Beep_01.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_02.ogg:system/media/audio/alarms/Alarm_Beep_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Classic.ogg:system/media/audio/alarms/Alarm_Classic.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Beep_03.ogg:system/media/audio/alarms/Alarm_Beep_03.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Alarm_Rooster_02.ogg:system/media/audio/alarms/Alarm_Rooster_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Classic_02.ogg:system/media/audio/ringtones/Ring_Classic_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Digital_02.ogg:system/media/audio/ringtones/Ring_Digital_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Synth_04.ogg:system/media/audio/ringtones/Ring_Synth_04.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/Ring_Synth_02.ogg:system/media/audio/ringtones/Ring_Synth_02.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Beat_Box_Android.ogg:system/media/audio/notifications/Beat_Box_Android.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Heaven.ogg:system/media/audio/notifications/Heaven.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/TaDa.ogg:system/media/audio/notifications/TaDa.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/Tinkerbell.ogg:system/media/audio/notifications/Tinkerbell.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Effect_Tick.ogg:system/media/audio/ui/Effect_Tick.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressStandard.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressSpacebar.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressDelete.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/KeypressReturn.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/VideoRecord.ogg:system/media/audio/ui/VideoRecord.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/camera_click.ogg:system/media/audio/ui/camera_click.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BeatPlucker.ogg:system/media/audio/ringtones/BeatPlucker.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CaffeineSnake.ogg:system/media/audio/notifications/CaffeineSnake.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BentleyDubs.ogg:system/media/audio/ringtones/BentleyDubs.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BirdLoop.ogg:system/media/audio/ringtones/BirdLoop.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CaribbeanIce.ogg:system/media/audio/ringtones/CaribbeanIce.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CurveBall.ogg:system/media/audio/ringtones/CurveBall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/EtherShake.ogg:system/media/audio/ringtones/EtherShake.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/FriendlyGhost.ogg:system/media/audio/ringtones/FriendlyGhost.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/GameOverGuitar.ogg:system/media/audio/ringtones/GameOverGuitar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Growl.ogg:system/media/audio/ringtones/Growl.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/InsertCoin.ogg:system/media/audio/ringtones/InsertCoin.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/LoopyLounge.ogg:system/media/audio/ringtones/LoopyLounge.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/LoveFlute.ogg:system/media/audio/ringtones/LoveFlute.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/MidEvilJaunt.ogg:system/media/audio/ringtones/MidEvilJaunt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/MildlyAlarming.ogg:system/media/audio/ringtones/MildlyAlarming.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/NewPlayer.ogg:system/media/audio/ringtones/NewPlayer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises1.ogg:system/media/audio/ringtones/Noises1.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises2.ogg:system/media/audio/ringtones/Noises2.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Noises3.ogg:system/media/audio/ringtones/Noises3.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/OrganDub.ogg:system/media/audio/ringtones/OrganDub.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/RomancingTheTone.ogg:system/media/audio/ringtones/RomancingTheTone.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SitarVsSitar.ogg:system/media/audio/ringtones/SitarVsSitar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SpringyJalopy.ogg:system/media/audio/ringtones/SpringyJalopy.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Terminated.ogg:system/media/audio/ringtones/Terminated.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/TwirlAway.ogg:system/media/audio/ringtones/TwirlAway.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/VeryAlarmed.ogg:system/media/audio/ringtones/VeryAlarmed.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/World.ogg:system/media/audio/ringtones/World.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DearDeer.ogg:system/media/audio/notifications/DearDeer.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DontPanic.ogg:system/media/audio/notifications/DontPanic.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Highwire.ogg:system/media/audio/notifications/Highwire.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/KzurbSonar.ogg:system/media/audio/notifications/KzurbSonar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/OnTheHunt.ogg:system/media/audio/notifications/OnTheHunt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Voila.ogg:system/media/audio/notifications/Voila.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CrazyDream.ogg:system/media/audio/ringtones/CrazyDream.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DreamTheme.ogg:system/media/audio/ringtones/DreamTheme.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/LowBattery.ogg:system/media/audio/ui/LowBattery.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Dock.ogg:system/media/audio/ui/Dock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Undock.ogg:system/media/audio/ui/Undock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Lock.ogg:system/media/audio/ui/Lock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/Unlock.ogg:system/media/audio/ui/Unlock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/moonbeam.ogg:system/media/audio/notifications/moonbeam.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/pixiedust.ogg:system/media/audio/notifications/pixiedust.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/pizzicato.ogg:system/media/audio/notifications/pizzicato.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/tweeters.ogg:system/media/audio/notifications/tweeters.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Big_Easy.ogg:system/media/audio/ringtones/Big_Easy.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Bollywood.ogg:system/media/audio/ringtones/Bollywood.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Cairo.ogg:system/media/audio/ringtones/Cairo.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Calypso_Steel.ogg:system/media/audio/ringtones/Calypso_Steel.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Champagne_Edition.ogg:system/media/audio/ringtones/Champagne_Edition.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Club_Cubano.ogg:system/media/audio/ringtones/Club_Cubano.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Eastern_Sky.ogg:system/media/audio/ringtones/Eastern_Sky.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Funk_Yall.ogg:system/media/audio/ringtones/Funk_Yall.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Savannah.ogg:system/media/audio/ringtones/Savannah.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Gimme_Mo_Town.ogg:system/media/audio/ringtones/Gimme_Mo_Town.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Glacial_Groove.ogg:system/media/audio/ringtones/Glacial_Groove.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Seville.ogg:system/media/audio/ringtones/Seville.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/No_Limits.ogg:system/media/audio/ringtones/No_Limits.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Paradise_Island.ogg:system/media/audio/ringtones/Paradise_Island.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Road_Trip.ogg:system/media/audio/ringtones/Road_Trip.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Shes_All_That.ogg:system/media/audio/ringtones/Shes_All_That.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Steppin_Out.ogg:system/media/audio/ringtones/Steppin_Out.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Third_Eye.ogg:system/media/audio/ringtones/Third_Eye.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Thunderfoot.ogg:system/media/audio/ringtones/Thunderfoot.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/BussaMove.ogg:system/media/audio/ringtones/BussaMove.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/CrayonRock.ogg:system/media/audio/ringtones/CrayonRock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DancinFool.ogg:system/media/audio/ringtones/DancinFool.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/DonMessWivIt.ogg:system/media/audio/ringtones/DonMessWivIt.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/HalfwayHome.ogg:system/media/audio/ringtones/HalfwayHome.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/Playa.ogg:system/media/audio/ringtones/Playa.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/newwavelabs/SilkyWay.ogg:system/media/audio/ringtones/SilkyWay.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Effect_Tick.ogg:system/media/audio/ui/Effect_Tick.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressStandard.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressSpacebar.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressDelete.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressReturn.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/VideoRecord.ogg:system/media/audio/ui/VideoRecord.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/camera_click.ogg:system/media/audio/ui/camera_click.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/camera_focus.ogg:system/media/audio/ui/camera_focus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/LowBattery.ogg:system/media/audio/ui/LowBattery.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Dock.ogg:system/media/audio/ui/Dock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Undock.ogg:system/media/audio/ui/Undock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Lock.ogg:system/media/audio/ui/Lock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/Unlock.ogg:system/media/audio/ui/Unlock.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Sceptrum.ogg:system/media/audio/ringtones/Sceptrum.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/alarms/ogg/Cesium.ogg:system/media/audio/alarms/Cesium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/alarms/ogg/Plutonium.ogg:system/media/audio/alarms/Plutonium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressStandard_120.ogg:system/media/audio/ui/KeypressStandard.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressSpacebar_120.ogg:system/media/audio/ui/KeypressSpacebar.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressDelete_120.ogg:system/media/audio/ui/KeypressDelete.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/effects/ogg/KeypressReturn_120.ogg:system/media/audio/ui/KeypressReturn.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Capella.ogg:system/media/audio/notifications/Capella.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/CetiAlpha.ogg:system/media/audio/notifications/CetiAlpha.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Polaris.ogg:system/media/audio/notifications/Polaris.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Pollux.ogg:system/media/audio/notifications/Pollux.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Procyon.ogg:system/media/audio/notifications/Procyon.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Aquila.ogg:system/media/audio/ringtones/Aquila.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/ArgoNavis.ogg:system/media/audio/ringtones/ArgoNavis.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Carina.ogg:system/media/audio/ringtones/Carina.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Centaurus.ogg:system/media/audio/ringtones/Centaurus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Cygnus.ogg:system/media/audio/ringtones/Cygnus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Draco.ogg:system/media/audio/ringtones/Draco.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Machina.ogg:system/media/audio/ringtones/Machina.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Orion.ogg:system/media/audio/ringtones/Orion.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Pegasus.ogg:system/media/audio/ringtones/Pegasus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Pyxis.ogg:system/media/audio/ringtones/Pyxis.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Rigel.ogg:system/media/audio/ringtones/Rigel.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Scarabaeus.ogg:system/media/audio/ringtones/Scarabaeus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Solarium.ogg:system/media/audio/ringtones/Solarium.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Adara.ogg:system/media/audio/notifications/Adara.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Arcturus.ogg:system/media/audio/notifications/Arcturus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Bellatrix.ogg:system/media/audio/notifications/Bellatrix.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Hojus.ogg:system/media/audio/notifications/Hojus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Lalande.ogg:system/media/audio/notifications/Lalande.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Mira.ogg:system/media/audio/notifications/Mira.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Proxima.ogg:system/media/audio/notifications/Proxima.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Shaula.ogg:system/media/audio/notifications/Shaula.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Spica.ogg:system/media/audio/notifications/Spica.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Tejat.ogg:system/media/audio/notifications/Tejat.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Upsilon.ogg:system/media/audio/notifications/Upsilon.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/notifications/ogg/Vega.ogg:system/media/audio/notifications/Vega.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Andromeda.ogg:system/media/audio/ringtones/Andromeda.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/CanisMajor.ogg:system/media/audio/ringtones/CanisMajor.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Girtab.ogg:system/media/audio/ringtones/Girtab.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Hydra.ogg:system/media/audio/ringtones/Hydra.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Perseus.ogg:system/media/audio/ringtones/Perseus.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Themos.ogg:system/media/audio/ringtones/Themos.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/UrsaMinor.ogg:system/media/audio/ringtones/UrsaMinor.ogg ignored.
PRODUCT_COPY_FILES frameworks/base/data/sounds/ringtones/ogg/Zeta.ogg:system/media/audio/ringtones/Zeta.ogg ignored.
PRODUCT_COPY_FILES device/samsung/toro/bcmdhd.cal:system/etc/wifi/bcmdhd.cal ignored.
PRODUCT_COPY_FILES device/sample/etc/apns-conf_verizon.xml:system/etc/apns-conf.xml ignored.
PRODUCT_COPY_FILES frameworks/native/data/etc/android.hardware.telephony.cdma.xml:system/etc/permissions/android.hardware.telephony.cdma.xml ignored.
PRODUCT_COPY_FILES device/samsung/tuna/bcmdhd.cal:system/etc/wifi/bcmdhd.cal ignored.
No private recovery resources for TARGET_DEVICE toro
host Java: guavalib (out/host/common/obj/JAVA_LIBRARIES/guavalib_intermediates/classes)
Copying: out/target/common/obj/JAVA_LIBRARIES/core_intermediates/emma_out/lib/classes-jarjar.jar
Copy: dx (out/host/linux-x86/obj/EXECUTABLES/dx_intermediates/dx)
Install: out/host/linux-x86/bin/aapt
Install: out/host/linux-x86/bin/aidl
external/guava/guava/src/com/google/common/collect/Maps.java:542: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
found : <K,V>java.util.TreeMap<K,V>
required: java.util.SortedMap<K,V>
SortedMap<K, V> onlyOnLeft = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:543: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
SortedMap<K, V> onlyOnRight = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:545: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,V>
SortedMap<K, V> onBoth = Maps.newTreeMap(comparator);
external/guava/guava/src/com/google/common/collect/Maps.java:547: incompatible types; no instance(s) of type variable(s) K,V exist so that java.util.TreeMap<K,V> conforms to java.util.SortedMap<K,com.google.common.collect.MapDifference.ValueDifference<V>>
required: java.util.SortedMap<K,com.google.common.collect.MapDifference.ValueDifference<V>>
target Export Resources: framework-res (out/target/common/obj/APPS/framework-res_intermediates/package-export.apk)
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
4 errors
make: *** [out/host/common/obj/JAVA_LIBRARIES/guavalib_intermediates/javalib.jar] Error 41
make: *** Waiting for unfinished jobs....
libpng warning: Ignoring attempt to set cHRM RGB triangle with zero area
aapt: warning: string 'gsm_alphabet_default_charset' has no default translation in frameworks/base/core/res/res; found: ko
Wow.
At that point, I'd scrap your repo, resync, and start anew. :(
It's been happening to me as well... I've resync'ed a few times... :(
I'm starting to think it's something to do with the open-jdk. I'm thinking of just trying to install J6 now.
The best way I've done it is simply editing within the zip.
Sent swiftly by Oliver using Android Central Forums
How do you edit within the zip?
I am running Kubuntu 12.04 and ARK will not let me edit anything in the zip, I have to extract to a folder first, make edits and re-zip, and then the installation aborts from cwm.
Johno
