I'm thinking of Rooting my Verizon Galaxy Note 2, mainly because of the problems I hearing with the 4.3 update rolling out on the 29th of this month. I've rooted my galaxy note 10.1 a couple of times, ran into some problems, but got through them with the help of people on XDA forums. I only did it to try the multi window app, but the main app I wanted, didn't work with Multi window (Draw Something). So I returned back to stock.
Here are the reasons I want to Root. I'd like to be able to wait awhile and see if others are having problems with the 4.3 update on their phones, then install if everything is okay. I've never had any problems with past phones having updates, My Droid X and Galaxy S lll. I'd also like to be able to use Google Wallet, not interested in ISIS. I have the app, but no Tap to Pay. I've seen that there is a way to do it on XDA if Rooted, but not sure it will work. I can also load a 4.4 Rom and that should allow it to work from what I've read. Lastly maybe to use the multi window app. That's a maybe, because prefer the multi window on my Note 10.1 much better than on the smaller Note 8 and 2. So those are the 3 reasons I want to root.
I see the method on here to Root also unlocks the Bootloader. I'm not sure what the advantages are to doing this and why I should need to for the reasons I posted above to root. If I do use that method and decide I don't want to stay rooted, I want to be sure I can get everything back to Official Stock and the Bootloader back locked. Is that even Possible?
Here are my questions:
1. Is there just a one click method to Root without unlocking the Bootloader? As I've said, not sure I need to unlock bootloader for the things I want to do with root.
2. If I use the method posted on the thread on this forum and Root and Unlock the Bootloader, Is it possible to return back to stock and get the Status of the device to Official and Count back to zero or none? Just in case I have problems with my phone and have to return it to Best Buy to get looked at.
3. Is it for sure that Google Wallet will work being rooted and flashing a 4.4 Rom or another method posted on XDA?
4. If I decide not to Root and take the 4.3 update and then do start to have problems with my phone, does anyone know if there will be a Root Method or Way to flash back to 4.1.2 which is the current version I have on my phone?
5. Is it for sure the Note 2 is going to get the 4.4 update? Maybe I can just wait and be patient, but would like to use Google Wallet. I hate having these cool features on your phone and not being able to take advantage of them, especially because Verizon blocked it.
Thanks in advance, I appreciate any help you peeps can give me. I'm just nervous because my phone is only about a month or so old, so not sure what to do yet, Root or just take the update.
