Will the new Sandisk 128GB MicroSDXC card SDSDQUA-128G-U46A work inside the Verizon Galaxy Note 2?
MrMLK
631
Re: Will the new Sandisk 128GB MicroSDXC card work inside the Verizon Galaxy Note 2?
Well, since it isn't available for sale anywhere and isn't even referenced on Sandisk's web site, its probably a moot point either way.
GMJeff
589
20
It is possible, but as the manual states 64 gb is max. Could just be because that is the largest available at the time of writing.
Samsung has a 128 gb version on their website as well, so who knows, until they try it.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
FlyingBackwards
50
Since MicroSDXC spec is up to 2TB, I guess the Note 2 can accept a 2TB card. (if and when it's available, probably at $1000 a card? :) )
farfromovin
6
Yes it'll work. I use a micro sd to sd card adapter in my Note 2 with a 128gb card and it's fine.
MrMLK
631
Where does one get a micro sd to sd card adapter, and how do you make it work with the Note 2?
Thanks.
vasekvi
1,176
So you have a 128gb microsd card that your note2 sees properly? And then you use a microsd to sd adapter to use in what your computer?
MrMLK
631
You have it backwards. He has a 128GB SD card that he uses an adapter to get it to read on the Note 2.
vasekvi
1,176
I was wondering. So he reads it with the usb port.
Sent from my AT&T Samsung Galaxy S4 using Tapatalk II
madisonjar
81
thats what I am wondering, can you take a pic and show us how that works, I dont mind dropping 100 bucks if I am for sure it will work!
