Has anyone figured out how to turn this sound off? I've looked everywhere I can think of. Thanks!
Camera ICS: https://forums.androidcentral.com/e...tails?id=com.moblynx.cameraics&token=PphaC_gJ has an option that allows you to turn the shutter sound off.
Edit: you can also look through http://forums.androidcentral.com/showthread.php?t=184182 (Turning camera shutter sound off)
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4 Beta
If you change your ringer setting to mute, it also silences the shutter noise.
Staying Average Since 1978
I'm now curious - is your phone running the MF1 build (4.1.2)? What does that final options screen look like - can you post a screenshot that shows the same section?My stock VZW S3 does not have the option to silence the shutter either.
