My TB is running stock ROM and rooted and it has dismal battery. I have been monitoring the "Battery use details" religiously and I noted that "Android System" is always the 2nd highest usage (Display is 1st highest, but that's a given)
Clicking on "Android System", I see the following packages:
- HTC Checkin Service
- Upgrade Setup
- BrcmBluetoothServices
- Google Backup Transport
- Android System
- Account & sync
- HTC Widget Download Manager
- Settings Storage
- com.android.qxdmlog
- Setup
- Settings
- Clock
- HTC Function Test Program 1.00g
- VPN Services
- Network Location
For the ones I color-coded in BLUE, I understand that it's needed, such as "Account & Sync", which is used for my Exchange push email.
However, for the ones I color-coded in RED, I DON'T understand what is this for. For example:
- What is "Setup" used for? Is this the "Setup" widget? Can I remove the .apk or .odx safely?
- What the heck is "HTC Function Test Program 1.00g"?
Using the Watchdog app, I noticed that Android Systems uses about 37 minutes of CPU time, when the phone has been off the charger for 59 minutes!
So for the red ones are the ones I THINK may cause the battery drain.
Any ideas?
- Upgrade Setup
- Android System
- Account & sync
- Settings Storage
- Setup
- Settings
- Clock
- VPN Services
- Network Location
Any ideas?
