Better battery life since update
Cyberhulk2000
14
the mid august stagefright securtiy update came with a new kernel version and im seeing a definite difference in battery especially in standbye
Yeah can't say for sure yet but wonder if it depends if Wifi &/or Mobile Data is on/off?
Battery sure got warm during the install though!?!
Posted via my Galaxy Note3 on the Android Central App
How were you able to receive this latest update?
Sent from my Galaxy Note 3 "Size Does Matter!"
Manually OTA: Settings/General tab/System updates/'Check for new system update'. However it may not yet be available to all locations yet....
it wiped the cache and dalvik partitions and all the apps had to be recompiled
paiton
