W windycityrider Active member Jul 18, 2010 27 0 0 Visit site Jun 20, 2013 #1 I'm guessing it's pretty safe to say that a phone case that fits a 16gb GS4, will also fit a 32gb GS4 since the only difference between the two will be internal?
Terb Trusted Member Apr 14, 2013 42 0 0 Visit site Jun 20, 2013 #2 You are correct. Posted via Android Central App Using My Galaxy S4
