Results 1 to 6 of 6
- 07-15-2012, 01:09 PM
Thread Author #1
- 07-18-2012, 02:28 AM #2
Re: Flash player not working
I just had the ICS operating system installed on my Moto Razr and I am LIVID! I noticed my flash wasnt working also so I went to the adobe site to see if there was a upgrade. On the first page when you go to playstore it says Adobe will no longer be updating for Android versions 4.0 and higher! Thats the dumbest thing Ive ever heard!!! This totally just put a damper on me even having the razr! I NEEEEEED a flash player!!!!
- 08-19-2012, 11:59 AM #3
- 08-19-2012, 08:10 PM #4
If you've already installed it at some point on the device you are using currently, in the play store go to your applications under "all" and it shows up available for install.
I don't believe it will help the OP, but for you others..... It should work. I've done reinstalls on my tablet and phone since they pulled it from the market without any problems. - 08-24-2012, 06:50 PM #5
- 09-24-2012, 02:22 PM #6
Reply
