Ok so yea I know I should have waited but I went ahead and upgraded and here are the issues ive had so far, let me know if anyone has had luck fixing these:
1. SD card keeps unmounting and mounting back, its a legit sandisk 64gb card, i had all my apps on it before the upgrade, it was crashing so often y re installed all my apps into main mem and left only music/pictures etc on the card and it seems to have gotten better but it still does it.
2. wireless charging with the LG official circle case is broken, it worked fine before the upgrade but now it start to charge when I put in on the plate but it stops after about 5 minutes, tried the usual resetting the phone, the plate etc. still does that, very frustrating..
These are the big issues ive had, the phone was unusuable for about 1 hour after the upgrade "completed" not sure what it was doing but eventually it settled down and everything seems to work (had to re install some apps because they would work).
So if anyone has any tips on fixing these 2 items I would appreciate it (no rooting and installing different rom please).
Thanks in advance
Thanks in advance
