+ Reply
Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By VW Maverick
    AC Question
    AC Question's Avatar
    Guest
    Angry wifi doesn't work properly on My Lg optimus G Pro
    The wifi signal on my status bar won't turn blue like before it stays white, same with the battery. It is updated to kit kat 4.4.2. i can't use my Fb, google and any other website. it says home wifi is not response in or from the internet. it's just problem with my phone. it works fine on my brother, sister, mom and in my dads phone but except mine. please help me........
  2. #2
    VW Maverick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Nitrogen OS 7.1.1 Nougat
    Default Re: wifi doesn't work properly on My Lg optimus G Pro
    Welcome.
    That is an odd occurrence.
    See if this helps: http://forums.androidcentral.com/amb...-problems.html
    Mav.
    B. Diddy likes this.
  3. #3
    welle wexetemovski's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe its never smart move to update the software, I know everyone suggesting you should, but if u ask me you should stay on a safe ground, couse with every update things are changing, things are mixing and you are getting in trouble.
  4. #4
    B. Diddy's Avatar
    Posts
    Global Posts
    78,110 Global Posts
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Keep in mind that in KitKat, the wifi icon in the notification bar no longer turns blue when you're connected--it's always white. If you want to check the connection status, you can check the Quick Settings by swiping down with two fingers, and looking at the wifi icon there. If that one is orange, then you're not connected to the Google servers. If it's white, then you're connected.
  1. Replies: 13
    Last Post: 12-27-2016, 10:02 AM
  2. Rain alarm pro
    By Silent Infiltrator in forum Android Apps
    Last Post: 02-17-2016, 05:28 AM
  3. text messaging on Samsung Galaxy Tab 4 10.1
    Last Post: 05-29-2015, 02:35 PM
  4. Moto g doesn't boot up
    Last Post: 08-05-2014, 06:36 PM
  5. Stream (speed) on Tunein Android
    By Stan Stark in forum General Help and How To
    Last Post: 08-05-2014, 03:29 PM
