A AC Question Sep 2, 2014 #1 After fully charging my tab 3 when i text or use it the battery goes down 2% every 10 mts or so. Why is that happening? What shoudl i do?
belodion Co-Ambassador Team Lead Moderator Jun 10, 2014 39,391 255 83 Visit site Sep 2, 2014 #2 Check in your battery usage stats to see if anything seems to be draining the battery abnormally. Consider also the possibility that the battery may simply be showing signs of age. Posted via Android Central App Upvote 0 Downvote
