Why is my S4 getting real hot and then draining the battery like 30 IN 5MIN?
A
AC Question
why is my s4 getting real hot and then drain the battery like 30% IN 5MIN
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,391
255
83
Re: why is my s4 getting real hot and then drain the battery like 30% IN 5MIN
Are you able to try a new battery, or at least, one known to be good?
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
Heat normally means a short or something drawing more current than it should. Where the problem lies is what has to be diagnosed. "Getting hot" is a symptom, not a cause.
As belodion said, if you put a new battery in the phone and the problem goes away, the old battery was bad. If not, something in the phone is causing the problem.
123dzo
