1. Jennifer Yang's Avatar
    So I have the Nexus 7 tablet (not sure what year..), and recently the battery drains a lot and it takes forever to charge. Now when I charge it, I noticed the battery percentage decreasing while I charge it. Like it was about 14%, so I left it charging for about 20 min to charge and then when I checked it again, it said it was 6%!? I tried turning it off fully and turning it on, but it was still the same. Sometimes it would charge (not 100%), but most of the time, the percentage keeps decreasing. PLEASE HELP!
    12-04-2014 07:18 PM
  2. belodion's Avatar
    Welcome to the forums.☺
    What an extraordinary coincidence....when charging my Lumia 1020 earlier, I noticed the battery percentage decreasing. Tried another charger, same spec, no problem. Tried a couple more times with the original charger and eventually it started charging normally again, so I guess it's a problem with the charger, the USB lead, or the phone USB port....same in your case, perhaps?
    I suppose that if no charge is passing into the device when connected to the mains charger, charge passes out, in my case to the advantage of the UK National Grid.
    12-04-2014 07:43 PM
  3. Rukbat's Avatar
    Sounds like the battery has reached the end of its life. (That could happen even to a 2014 model if you keep using it until the charge gets down close to 0 - you should charge at no less that 40% whenever possible). Turn the tab off and leave it plugged in overnight and it'll probably be at 100% (or close to it - a dieing battery can lose 5% just turning the device on). But it won't hold the charge as long as it used to, it'll take longer to charge and it won't get a net charge when it's on. (The amount of charge going into the battery is the amount the tab is allowed to draw from the charger minus the amount being used by the tab. If the battery is old, it leaks electricity, and that's usage. The older it is, and the more it's been abused [like letting it discharge almost all the way], the worse it gets.)
    12-04-2014 08:37 PM
  4. dhruv gupta 111's Avatar
    I had the same problem with my smartphone and changed the battery with no luck. On changing the usb cable , my phone was back to normal So try changing the usb able and/or charger.
    belodion likes this.
    12-01-2015 05:43 AM
  5. belodion's Avatar
    Welcome to the forums and thank you for sharing the tip.
    I agree, the USB lead is the first suspect. A damaged or dirty USB port connector is also worth checking, as well as the other links in the charging chain.
    12-01-2015 07:12 AM
  1. Nexus 5 vs Nexus 6
    By bjrosen in forum Phone Wars
    Last Post: 12-30-2014, 03:52 PM
  2. Replies: 2
    Last Post: 12-06-2014, 09:10 PM
  3. My Be G3
    By Jord1511 in forum LG G3
    Last Post: 12-05-2014, 12:13 AM
  4. Replies: 2
    Last Post: 12-04-2014, 08:46 PM
