A
AC Question
Samsung Gear Fit starting up but not able to get into functions
Gear fit is starting up, am able to connect to Bluetooth and is recognised by Samsung Kies 3 however....
After the initial splash screens, it boots into a screen that says Gear Fit, Samsung Apps, Gear Fit Manager (in both Chinese and English). The right side of the screen has an arrow to the next screen which has an image of the Gear fit, text is Gear Fit (C17B), Gear Fit Manager (both in Chinese and English again. Arrow on left side of screen takes me back to the previous screen...
Can only go from one screen and back again to the other - no other options or functions available. Have tried resetting (7 seconds) with no effect.
Was even able to upgrade the firmware using Samsung Kies 3 - still no change.
