A
AC Question
samsung grand 2 battery got hit with something and having a small dent so is it safe to use battery performance is normal.
I think its wise for you to have it checked rather than risk it leaking into the motherboard. Some batteries are usually made of a metallic casing, so dents are never deep enough to reach inside. But I think you should take it to someone for them to check.samsung grand 2 battery got hit with something and having a small dent so is it safe to use battery performance is normal.
