Verizon phones that work internationally?
A
AC Question
Are there any Verizon Android phones that work internationally, both voice and data? I was looking at the Galaxy S5, but I've read that data won't work internationally (outside of the US). Are there any truly international Verizon phones?
Thanks
srkmagnus
Retired Moderator
May 23, 2010
13,434
210
Thanks
The Verizon model of the Galaxy S5 will work internationally. It's just data will be limited to what carrier you choose to go with (Internationally) and whether they support the device. Here is what the device will support:
Network :
LTE Band 13/4 (700/1700 MHz)
CDMA/1xEVDO Rev. A (800/1900 MHz);
Global - EDGE/GSM (850/900/1800/1900), HSPA/UMTS(850/900/1900/2100)
You can contact carriers in advance and check what they will support.
smokedog87
