A
AC Question
My phone is a oneplusone running on cyanogen os version 12.0, it worked perfectly fine until a few weeks ago when I tried to connect to the home WI-FI it gave me “authentication problem” instead of connected.
I have since checked the password in the modem settings to verify that I have the correct password which I do. It will not connect to any other Wi-Fi either the only way that I have found to get the Wi-Fi to connect is to turn the phone on and off again which allows it to connect but if I lose or leave the Wi-Fi it won’t reconnect it just gives “authentication problem”.
Any ideas on what the issue is and any ideas on fixes.
