A
AC Question
Not completely but partially, it will not turn off, but it will turn on and with the power off menu. When i can turn it off ( rarely ) it is delayed and turns off quickly then right back on. Before you ask, i did try the reset, even factory reset, im thinking it is some update to something but i have no idea i do know that it started when i tried to take a screenshot. It is a Droid Razr M XT907, if anyone can help that would be amazing thanks.
