A
AC Question
Hey all, so some backstory, this thing used to last for 2 days, and now it just doesn't. I have tried a factory reset etc, I am beginning to think it's my battery.
I just got a new device because my last one just wouldnt turn on after setting it down one day, it is always very hot (running around 106 if the screen is on). My battery usage on the graph is a straight plummet, I get about 9 hours per full charge and I keep my screen at 30% with all services off besides data.
I am wondering if I have a faulty battery and that is why my brand new device is having the same issue as my old one.
I use a Tenergy quick charger, I have tried using the Qualcomm snapdragon battery guru but it says it is incompatible with my device, I have wiped my SD card to be sure there wasnt a corruption issue there, and I have wiped the phone as of 2 days ago.
I have also tried using safe mode to see if it minimizes drain but it does not.
