A AC Question May 27, 2016 #1 I tried almost every in settings to fix this problem lockscreen I just trying to enable the ripple affect on the lock screen but cannot figure it out.
the tall guy Q&A Team Sep 23, 2013 7,210 0 0 Visit site Jun 2, 2016 #2 Hi, do you have a pattern / pin / fingerprint security enabled on the lockscreen, if you do then the ripple effect won't work. You need to have "swipe" enabled as the screen unlocking method. Upvote 0 Downvote
