A
AC Question
Hello, could someone help I just turned off my S7 edge to swap to a different sim then put it back an noticed all the apps on the sd card weren't showing up then went to storage an it says corrupt checked to see if the sd card wasn't sitting in tray right but it seemed to be fine put sd card in card slot on computer an works fine copied everything. Is there any way to get sd card working again on s7 or is doing a format the only way? as id prefer not too as that means having to download all apps again. Any help would be appreciated thanks.
